Schwind
#1 Posted : Thursday, May 19, 2011 3:50:27 PM(UTC)
Schwind
Wash arm does not spin and water is not pumped out. The timer seems to be functioning okay. I don't hear any hum from the motor when I think I should and checking I find 120 volts in. Also, when unit is off I find no motor resistance in those wires. Am I correct in assuming a failed motor? If so should I replace just the motor or the pump-motor unit? I got this dishwasher used about a year ago at a recycle store and don't know its age but it looked newish. Is it worth repairing??
#2 Posted : Tuesday, May 24, 2011 2:15:07 PM(UTC)
I could not find anything on a 48BA, the following is for a 45BA.
The pumps will be the same
Replacement parts for General Electric GSD720P-45BA | AppliancePartsPros.com
[COLOR="DarkRed"]I don't hear any hum from the motor when I think I should and checking I find 120 volts in. Also, when unit is off I find no motor resistance in those wires. Am I correct in assuming a failed motor?[/COLOR]
Yes it does sound like the motor is toast.
[COLOR="DarkRed"]
If so should I replace just the motor or the pump-motor unit?[/COLOR]
I would replace the motor and pump.
[COLOR="DarkRed"]I got this dishwasher used about a year ago at a recycle store and don't know its age but it looked newish. Is it worth repairing??[/COLOR]
It may be if it is in great shape but only you can answer that.
The motor/pump is on the first page of the parts.
At over $130.00 it is a pretty hefty investment into it.
