My Whirlpool washer doesn't fill. You can hear the motor running, but no water. The hoses and filters are clear. Any suggestions? Thanks.
Rank:: Advanced Member
If the machine runs but no water then the first thing I would check is the water level switch. Perhaps the contacts in the switch are welded together so the machine thinks it is full. Here is the tech sheet https://www.servicematters.com/d...0Sheet%20-%208558184.pdfAlso have you tried different water levels and temp settings, this may help troubleshoot the problem. |
THIS FORUM IS DEAD!!!!!!! |
