bjm46
#1 Posted : Saturday, November 15, 2008 1:25:50 PM(UTC)
bjm46
My Whirlpool washer doesn't fill. You can hear the motor running, but no water. The hoses and filters are clear. Any suggestions? Thanks.
#2 Posted : Saturday, November 15, 2008 7:53:53 PM(UTC)
If the machine runs but no water then the first thing I would check is the water level switch. Perhaps the contacts in the switch are welded together so the machine thinks it is full.
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%208558184.pdf
Also have you tried different water levels and temp settings, this may help troubleshoot the problem.
Whirlpool washer won't fill (Washer Repair)
by Jmccal7 9/9/2014 7:24:00 PM(UTC)
Whirlpool washer won't fill with cold water (Washer Repair)
by tjwinters 3/17/2013 12:43:54 PM(UTC)
Whirlpool Washer Won't fill (Washer Repair)
by jamie_pancake@yahoo.com 9/22/2012 3:32:02 PM(UTC)
by Wilmalcolm 7/28/2012 4:42:25 AM(UTC)
whirlpool washer won't fill (Washer Repair)
by rambo2 3/5/2012 8:36:41 AM(UTC)
Whirlpool Washer won't fill (Washer Repair)
by Katheryn 1/2/2012 8:55:52 AM(UTC)
Whirlpool washer won't fill with water (Washer Repair)
by Evonne 10/22/2008 12:52:24 PM(UTC)
