eddy123
#1 Posted : Saturday, November 15, 2008 4:53:48 PM(UTC)
eddy123
I have a kenmore dryer that I have ordered a front door rubber switch from AppliancePartsPros.com that I need to replace. What is the procedure to replace the switch. Seems it can't be directly removed and replaced (wires are too short and would fall inside if I disconnect old switch). This implies I have to remove a cover and replace it.
What would the procedure be to do this replacement?
switch part #AP3135340
libertyappl
#2 Posted : Sunday, November 16, 2008 9:28:10 AM(UTC)
libertyappl
This isn't your exact model but it should help you get into your machine.
http://www.servicematters.com/tech_ref/JA/ja_main.htm
Nat
eddy123
#3 Posted : Sunday, November 16, 2008 1:35:12 PM(UTC)
eddy123
Unfortunately, this URL only pointed me to the main page. Did now know where to go from there... but thanks for the reply.
Ed
libertyappl
#4 Posted : Sunday, November 16, 2008 2:53:21 PM(UTC)
libertyappl
If you want to send me an email I can just send you the manual, it's too big to post.
Nat
