2 Pages12>
tmacky34
#1 Posted : Saturday, November 15, 2008 5:36:42 AM(UTC)
tmacky34
When I turn the oven knowb to a temperature, the element lights up red hot. However the gas never kicks on and the element sits there red hot.
Any suggestions?
Tmacky
libertyappl
#2 Posted : Saturday, November 15, 2008 5:39:00 AM(UTC)
libertyappl
Most likly the ignitor isn't hot enough to open the valve or the valve itself is bad.
Here's the breakdown on your unit. Model MGR4411BDW
Nat
tmacky34
#3 Posted : Saturday, November 15, 2008 5:45:11 AM(UTC)
tmacky34
Is there a way to test the ignitor? Also if the igniter was bad would it have an effect on the burns on the top of the stove?
libertyappl
#4 Posted : Saturday, November 15, 2008 5:50:14 AM(UTC)
libertyappl
Those ignitors should be bright yellow in the center, like the sun, if they are hot enough to light. And no that wouldn't effect the burners on top. Are your burners having a problem too?
Nat
tmacky34
#5 Posted : Saturday, November 15, 2008 5:54:51 AM(UTC)
tmacky34
no problem with the burners. The ignitor is getting bright yellow, so I'm confident the ignitor is good.
libertyappl
#6 Posted : Saturday, November 15, 2008 5:57:05 AM(UTC)
libertyappl
Then you will probably need to check the valve itself with an ohm meter. Part Valve, oven
Nat
tmacky34
#7 Posted : Saturday, November 15, 2008 6:25:32 AM(UTC)
tmacky34
With the OHM meter what exactly will I be looking for.
libertyappl
#8 Posted : Saturday, November 15, 2008 6:52:55 AM(UTC)
libertyappl
This is what to do.
Set the ohmmeter to the R x 1 scale.
Touch the test leads to the solenoid terminals
on the gas safety valve. The meter
should indicate less than 1 ohm
Nat
tmacky34
#9 Posted : Saturday, November 15, 2008 7:00:54 AM(UTC)
tmacky34
I will try it in a few minutes, I have to find my VOM.
Thanks!
tmacky34
#10 Posted : Sunday, November 16, 2008 2:23:40 PM(UTC)
tmacky34
my meter has 2k setting and when I measure across the terminals it reads .001. Oncew I turn the oven on then the meter continually jumps around. But the gas still doesn't come on. Any suggestions?
Oven won't come on (Oven Repair (including Ranges and Cooktops))
by Nancy T. 6/24/2010 4:14:37 AM(UTC)
oven won't come on after turning off cleaning (Oven Repair (including Ranges and Cooktops))
by badtothebone 10/26/2009 10:16:57 AM(UTC)
2 Pages12>
