ds1018
#1 Posted : Thursday, May 19, 2011 2:30:27 PM(UTC)
ds1018
I was getting the "F2" error on my whirlpool oven when trying to bake. The resistance on the temp sensor matched the expected OHMS as stated on these forums so I replaced the control panel.
I replaced it with the following part.
AP4321499 (W10108320) CNTRL-ELEC 1 $74.54
After replacing it I got the F2 error again, pulled it back away from the wall, entered the diagnostics, saw that current temp was accurate, cleared the error, and tried again.
After several attempts with the oven up against the wall and more with it pulled out away from the wall we realized that it would only work when pulled away from the wall and would always give the F2 error when pushed up against it.
I have a 4 and a 10 year old so using the oven with it pulled out into the kitchen is not an acceptable solution. Any ideas on what could be causing the problem? It doesn't seem like there's much else in there, a temp sensor, a light, and some igniter wires. I can't think of anything else to replace.
Thanks in advance!!!!
David
#2 Posted : Thursday, May 19, 2011 6:34:17 PM(UTC)
David,
It's hard to believe but it looks like the new control board is defective. It has to be exchanged under the part warranty.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL WFG114SVB0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION | AppliancePartsPros.com
Adam / APP Team
#3 Posted : Friday, May 20, 2011 7:34:17 AM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
David,
I have forwarded your order information over to our call center manager to have someone contact you for a replacement. Please be sure to have you model and serial number available for warranty.
You may also call us toll free at 1-877-477-7278 and one our representative will be glad to assist you.
Thank you for choosing Appliance Parts Pros.com.
ds1018
#4 Posted : Wednesday, June 1, 2011 7:58:23 AM(UTC)
ds1018
I received a new control unit and I am still getting the F2 error. Any other
ideas?
The unit looks exactly like the original so I'm guessing it's the right one. Is there anything else that could be causing this?
Serial Number: vew4305235
Model Number: wfg114svb0
cverrey
#5 Posted : Wednesday, June 1, 2011 2:04:49 PM(UTC)
cverrey
Hey David I have whirlpool model SF114PXSQ1 and I am having the same issue as you! I have replaced the temperature sensor and the computer and I still get the F2 code. While the oven is pulled away from the wall I noticed there is not much insulation between the ERC and the oven. My ERC is blistering hot on the bottom even with the back panel off and I can see white discoloration on the bottom where the plastic has heated up. I am going to try going to Home depot to get some more insulation to stick between the oven and ERC box to see if that fixes the issue. I'll let you guys know if it worked or not and try to get some pictures.
#6 Posted : Wednesday, June 1, 2011 3:26:21 PM(UTC)
David,
Very likely [COLOR="Red"]cverrey[/COLOR] is on the right track. You can give it a try too or just wait for his update.
ds1018
#7 Posted : Wednesday, June 1, 2011 7:45:46 PM(UTC)
ds1018
I look forward to hearing back from you on how well the insulation works!
cverrey
#8 Posted : Thursday, June 2, 2011 7:09:42 AM(UTC)
cverrey
So I took the heat shield panel off and I have the oven sitting about 1.5" to 2" away from the wall and so far after making several TV dinners and cookies over about a 3 hour span I have gotten no F2 error message. I have been watching the heat of the wall closely and it does not appear to be heating up. I think this is allowing enough airflow to go through and not fry the computer. Just to be safe I want to put some reflective heat insulator along the wall directly behind where the oven is and line the bottom and side of computer. I'll also be trying to see if I can insulate it enough to stick the heat panel back on and move it closer to wall without getting the dreaded F2 message. I'll be trying to get some pictures up of the whole thing as well as a set of conditions that work, I am going down to home depot today to pick up the insulator.
kdressl
#9 Posted : Thursday, May 1, 2014 10:03:14 AM(UTC)
kdressl
This is just another thing you can watch out for if you receive an Error after replacing the control panel. I live in Costa Rica and have an open lot next to my home so from time to time we have mice infestations. They got into the insulation around the oven and urinated in the insulation.
When I turned the stove on the stench was unbelieveable.. and the control panel gave the F2 error. We replaced all the insulation, cleaned everything, replaced the control panel and the temperature sensor and everything looked fine but the oven wouldn't shut off. During the night the F2 error started again and was beeping. We had the stove out from the wall so that wasn't the problem.
After checking everything out again, we noticed that there was an almost invisible amount of mouse urine on the control panel. SO, it was washed clean with soap and water and left in the sun to dry. The housing of the control panel was also recleaned. When hooked up again, the F2 error was gone and both the old and new temp sensors are now working. Now all we have to figure out is how to keep mice out of the house.... almost impossible here.
