dcascino
#1 Posted : Thursday, November 13, 2008 1:25:59 PM(UTC)
dcascino
My kenmore top loading washer has developed a leak somewhere.. during the spin cycle only... during the first drain & refill for rinse there is no water but late in the spin cycle I see some water oozing out from under the unit. I took the cabinet off the frame to check the hoses and found that there is water marks on the inside of the cabinet almost completely to the top and I also found a little water trail on the outide of the washer from the space between the top portion of the cabinet (the part where the lid is attached ) and the bottom cabinet. Any thoughts on what is really happening.
Thanx
Dan
magician59
#2 Posted : Thursday, November 13, 2008 2:41:43 PM(UTC)
magician59
With the cabinet off, shunt the lid switch and run it through a cycle on the highest water level. Watch as it spins, and you will see where the water is coming from.
dcascino
#3 Posted : Thursday, November 13, 2008 6:44:13 PM(UTC)
dcascino
which pins do I clip together.
Dan
dcascino
#4 Posted : Thursday, November 13, 2008 7:40:29 PM(UTC)
dcascino
So I ran the rinse and spin with no leakage. So Now I am wondering if maybe there might be a leak in one of the hoses that feeds the bleach/softener trays and this leak put enough water on the lip that surrounds the basket/tub it is about 2 inches wide and is like a trough. And then when the washer goes into spin mode the vibration throws the water around.
Dan
magician59
#5 Posted : Friday, November 14, 2008 5:01:26 AM(UTC)
magician59
How much water are you seeing? What side of the machine are you seeing it on?
dcascino
#6 Posted : Friday, November 14, 2008 6:10:49 AM(UTC)
dcascino
The water is generally on the left side (the side with the bleach / fabric softener dispenser) there is a small space (1/64th of an inch) between the base cabinet and the lid assembly where this bleach / fabric softener dispenser is mounted and there are hoses running along this side under this lid assembly.
Dan
Guest (5)
