coaner
#1 Posted : Tuesday, May 17, 2011 11:17:09 AM(UTC)
coaner
I have a Kirkland Signature by Whirlpool washer model SAWS800JQ1 that drains but it will not spin or fully agitates. If the basket is spined manually the washer will pick up speed but will stop at times. I have taken most of it apart but cannot see where the problem is. Please help. :confused:
#2 Posted : Tuesday, May 17, 2011 1:09:55 PM(UTC)
Remove the washer cabinet and check the motor drive coupling (#13 on the diagram). The instructions are attached.
- The motor coupling Part number: AP3963893
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL SAWS800JQ1 WASHER - DIRECT DRIVE | AppliancePartsPros.com
File Attachment(s):
How to remove the washer cabinet.doc (21kb) downloaded 40 time(s).
How to remove the pump.doc (25kb) downloaded 35 time(s).
How to replace the motor drive coupling.doc (25kb) downloaded 46 time(s).
coaner
#3 Posted : Tuesday, May 17, 2011 2:20:01 PM(UTC)
coaner
Thanks I will try that. What would cause the water to drain but the basket not to spin or agitate?
#4 Posted : Tuesday, May 17, 2011 8:13:58 PM(UTC)
The motor has a double shaft. The pump is mounted on one side and the transmission is connected to the shaft on the other side through the motor coupling.
obrieng2
#5 Posted : Friday, May 27, 2011 3:10:05 PM(UTC)
obrieng2
I replaced the motor coupler and still won't agitATE OR SPIN
#6 Posted : Friday, June 3, 2011 2:58:06 PM(UTC)
Sorry for the delay.
I understood it does spin if you force it manually. What does it do when it should agitate?
BTW, I did not recommend to replace the coupler. I just advice to check it.
