jeff23185
#1 Posted : Thursday, November 13, 2008 7:26:21 AM(UTC)
jeff23185
At the conclusion of the complete cycle, water is leaking from the bottom left side of the unit onto the floor. In fact, the insulation inside the bottom-most protection panel (under the actual dishwasher) is damp. I suspect this leak is caused by either the float or the (left) tub gasket. Am I close?
abadfish66
#2 Posted : Thursday, November 13, 2008 7:59:26 AM(UTC)
abadfish66
Take off that toekick (access panel) run the dishwasher and see if it is leaking from underneath at the motor.
jeff23185
#3 Posted : Thursday, November 13, 2008 4:07:11 PM(UTC)
jeff23185
Thanks. No leak from underneath (dry floor, motor/pump replaced last year). Leak is drip from bottom of door frame at end of cycle. Water in dishwasher empties properly (drain and pump ok?). Power of deduction: must be float and/or left/right gasket. You agree?
#4 Posted : Friday, November 14, 2008 1:31:34 AM(UTC)
Try adjusting the door latch at the top of the frame, might just fix the problem.
jeff23185
#5 Posted : Saturday, November 15, 2008 1:08:39 PM(UTC)
jeff23185
upon closer inspection, I found that the door gasket was torn/corroded at the base of the door! I've ordered a new one and will install it asap. thanks...
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
Kenmore Elite 665.13929K015 Dishwasher Leak (Dishwasher Repair)
by JROTN 12/22/2022 5:12:45 PM(UTC)
Dishwasher Leaking Kitchenaid KDTE334DSS0 (Dishwasher Repair)
by Bscott46 10/4/2022 5:16:08 PM(UTC)
Maytag dishwasher leak from bottom of door (Dishwasher Repair)
by Guest 7/27/2022 1:58:00 PM(UTC)
Dishwasher leaks after inlet valve (Dishwasher Repair)
by amazingAZ 6/2/2022 8:57:54 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
LG Dishwasher Leaking When First Turned On (Dishwasher Repair)
by artriumph 4/22/2021 1:13:56 PM(UTC)
dishwasher leak varies (Dishwasher Repair)
by scottsasa 1/3/2021 4:23:28 AM(UTC)
Delayed dishwasher leak (Dishwasher Repair)
by budflanksteak 12/11/2020 5:03:57 AM(UTC)
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 9/5/2019 5:49:20 PM(UTC)
Whirlpool dishwasher leaking bottom (Dishwasher Repair)
by nkaufman1 5/14/2019 1:50:41 AM(UTC)
Bosch Dishwasher Leaking into base (Dishwasher Repair)
by Canadianice 4/12/2018 8:18:35 AM(UTC)
Dishwasher leaking underneath [PHOTOS] (Dishwasher Repair)
by jd514 1/6/2018 11:16:52 AM(UTC)
Dishwasher leak at float (Dishwasher Repair)
by warrenmott1 1/2/2018 12:37:31 PM(UTC)
Kemore Dishwasher Leak (Dishwasher Repair)
by Chevyman22360 7/19/2017 11:40:09 AM(UTC)
