Sinchak59
#1 Posted : Sunday, May 15, 2011 12:49:56 PM(UTC)
Sinchak59
Refrig. wont cool set thrmostate to 9 on both freezer and refrig. not cooling. Cond, is clean compressor comes on. I measured the amp draw at compressor started at 7.88 and with in 2-3 seconds dropped to .67. Checked cap. with ohm meter appears to be good. I have checked this several times with same result. Clicking can be heard at circut board. All lights and fans are working. Maybe the run windings may be bad?
#2 Posted : Monday, May 16, 2011 5:16:53 AM(UTC)
The current draw is below normal, I would suspect a refrigerant leak or clogged capillary, check to see if there is any frost on the evaporator.
Bought refrigerator wont cool and i smell freon leaking. (Refrigerator & Freezer Repair)
by Tressa1 3/23/2012 6:15:11 AM(UTC)
Refrigerator Wont Cool (Refrigerator & Freezer Repair)
by cottonslurpy 1/28/2008 8:14:10 PM(UTC)
