wobbly44
#1 Posted : Wednesday, November 12, 2008 2:04:30 PM(UTC)
wobbly44
My washer wobbles but unlike other postings I do not have a powder residue and it doesn't screech when it stops. I just wonder what part would help fix this. Does anyone know?
libertyappl
#2 Posted : Wednesday, November 12, 2008 2:17:55 PM(UTC)
libertyappl
Check your snubber on the base, part # 21001161 or AP4024496 from this site.
Here's your parts breakdown Model PAV2200AWW
Nat
wobbly44
#3 Posted : Wednesday, November 12, 2008 2:30:13 PM(UTC)
wobbly44
Is there an installation steps and procedures manual online somewhere?
v2k04
#4 Posted : Wednesday, November 12, 2008 3:35:06 PM(UTC)
v2k04
Does the tub lean real hard to the right side? There was a service bulletin on the Performa's and the kit came with a new baseplate,snubber, and springs they also shook a lot and on a raised wood floor they were real bad
wobbly44
#5 Posted : Wednesday, November 12, 2008 4:54:24 PM(UTC)
wobbly44
How do I get hold of this kit?
Where do I get installation instructions?
v2k04
#6 Posted : Wednesday, November 12, 2008 5:37:20 PM(UTC)
v2k04
Replace original snubber with kit 12002357. The replacement of the snubber and six springs (included in the kit) will reduce tub lean to an acceptable level. If you still experience tub lean after replacement of the snubber, confirm the snubber is centered properly and check for possible damage to the base.
v2k04
#7 Posted : Wednesday, November 12, 2008 8:30:47 PM(UTC)
v2k04
You can order it from this site
libertyappl
#8 Posted : Thursday, November 13, 2008 8:00:54 AM(UTC)
libertyappl
The part number for tis site is AP4009638.
Nat
#9 Posted : Friday, November 14, 2008 3:01:37 AM(UTC)
Enter in the search box my article "Maytag Performa washer snubber replacement".
Note that you will not need to pull off the tranny pulley and the last one I did I didn't need the extra long screws, just be careful and loosen all the housing screws symetricaly to remove the brake spring tension.
Inspect the base under the snubber, if pitted badly, you will need a new base.
