Sanco777
#1 Posted : Friday, May 13, 2011 9:38:57 AM(UTC)
Sanco777
On my Maytag range I just replaced the over sensor, control panel and the door lock. Turned on the burners they work, turn on the broiler, it works but the oven will not heat up. You can hear the clicks as thought it is advancing to the requested temperature but the temperature/oven is not hot. What could be the problem. Could it be a faulty sensor or control panel or is the element shot. THanks
magician59
#2 Posted : Friday, May 13, 2011 11:27:05 AM(UTC)
magician59
First thing to check is to make sure all the electrical connections are secure.
Sanco777
#3 Posted : Friday, May 13, 2011 12:49:55 PM(UTC)
Sanco777
All of the electrical connections are good. Rechecked everything, but to no good. The oven still does not heat. I also want to say that all my problems started after I had cleaned the oven and the door would not open or fan would not shut off. Was told to replace the sensor, panel and door lock. Now since the wiring is ok to the panel should I replace the bottom element. Broiler is good. Thanks for your help
magician59
#4 Posted : Friday, May 13, 2011 1:55:25 PM(UTC)
magician59
Check the element for continuity (disconnect power to the range, first.). If it's open, replace it.
Guest (5)
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Maytag range oven (Oven Repair (including Ranges and Cooktops))
by C Hardin 10/30/2014 4:23:34 PM(UTC)
Maytag range lower oven not heating (Oven Repair (including Ranges and Cooktops))
by KA123 9/8/2014 6:10:19 PM(UTC)
Maytag Range Bake Light Flashing (Oven Repair (including Ranges and Cooktops))
by carlking2 12/26/2013 12:31:10 PM(UTC)
maytag range orifices (Oven Repair (including Ranges and Cooktops))
by chadk66 8/31/2013 3:38:29 PM(UTC)
Remove Maytag Range GlassTop, How to (Oven Repair (including Ranges and Cooktops))
by BobYates 4/7/2012 5:58:49 PM(UTC)
Maytag range clock control (Oven Repair (including Ranges and Cooktops))
by res04n70 12/27/2011 5:17:42 AM(UTC)
Maytag range (Oven Repair (including Ranges and Cooktops))
by txgbe270 8/21/2011 5:07:52 PM(UTC)
Maytag Range / MER5755QAQ (Oven Repair (including Ranges and Cooktops))
by jeffro390 6/6/2011 9:26:31 AM(UTC)
Maytag Range (Oven Repair (including Ranges and Cooktops))
by ADAMS48 6/1/2011 6:11:39 PM(UTC)
Maytag range. Cooktop functioning, but oven just says OFF (Oven Repair (including Ranges and Cooktops))
by watkinsnc 11/21/2010 10:21:52 AM(UTC)
Maytag Range lower bake element won't work (Oven Repair (including Ranges and Cooktops))
by donnabass8 11/17/2010 11:40:30 AM(UTC)
Any idea of naming scheme for Maytag ranges? (Oven Repair (including Ranges and Cooktops))
by rtom 11/9/2010 8:38:29 AM(UTC)
by specialfx 10/30/2010 6:34:39 AM(UTC)
by specialfx 10/29/2010 2:59:51 PM(UTC)
