Unit Acts Like It Has Just Finished A Complete Cycle And Is Now Flashing The Clean Indicator On The Panel. Light Flashes Seven Times In A Sequence Then Pauses(error Code) Panel Is Free To Select Any Option But Will Not Procede With The Selected Option. Have Tried Cancel Option,power Down At Breaker Option, Hoping For Reset. Any Diagnostics Help On The Error Code Would Be Appreciated.(kenmore Elite Dishwasher Model 665.17052400). No Apparent Obstructions Of Any Kind In The Machine.
You have been a member since:: 9/10/2007(UTC) Posts: 9,586
Open door and hit hi temp scrub,then energy saver dry,then repeat ( or similar buttons), close door and hit cancel button, this should clear the hung computer.
