I just installed a new washer and dryer. As I was pushing the washer back to the wall I got a significant shock. If you lean against the washer and touch the back of the control panel you get a jolt. Tested the wall outlet, tester says it is wired correctly with proper ground. 125 volts. I don't want to use it till I figure out what's wrong. Anyone have any ideas?
Originally Posted by: jimin8  I just installed a new washer and dryer. As I was pushing the washer back to the wall I got a significant shock. If you lean against the washer and touch the back of the control panel you get a jolt. Tested the wall outlet, tester says it is wired correctly with proper ground. 125 volts. I don't want to use it till I figure out what's wrong. Anyone have any ideas? did u just buy it ??
If its brand new, CALL FOR SERVICE!!! If its used, unplug it and open the console and have a look.:)
Get it fixed under warranty just make sure they do not try and bill you for the service call as this is a safety issue.
Sounds like the console is plastic with the back of the console metal and a wire is touching the metal back plate which is floating because of the plastic mounting. In the old days they would of had to run a ground stap from the back plate to chassis to ensure it was grounded. |
THIS FORUM IS DEAD!!!!!!! |
