Mary2020
#1 Posted : Tuesday, November 11, 2008 8:30:21 AM(UTC)
Mary2020
My icemaker has stopped making ice. The arm still moves but I do not hear the water running through the unit I have checked all the lines and hoses nothing is loose or bent. I can pour water into the icemaker and it will freeze ice so can you tell me what the problem might be and how I can repair it?
magician59
#2 Posted : Tuesday, November 11, 2008 8:43:55 AM(UTC)
magician59
If you can disconnect the water valve to the ice maker, you can check it by applying 120 VAC to its terminals, and seeing if water flows through it. Do this by keeping the water line attached to the valve, and placing it inside a 5 gallon bucket or similar container. Find an old power cord and attach terminals or alligator clips to the end you connect to the valve. Be very careful not to let the ends touch each other or any other metal. Plug it in just long enough to verify water flow or not.
You'll save a costly service call/diagnosis by doing this.
Whirlpool Side by Side with icemaker Model WRS588FI (Refrigerator & Freezer Repair)
by Guest 4/19/2024 4:08:15 PM(UTC)
Whirlpool WRS325SDHB08 Icemaker works intermittently (Refrigerator & Freezer Repair)
by donl1150 3/2/2024 5:04:55 AM(UTC)
Kennmore icemaker does not work (Refrigerator & Freezer Repair)
by Guest 11/24/2023 4:57:24 AM(UTC)
ICEMAKER ISSUE: Kitchenaid KSRS27QFAL00 Superba (Refrigerator & Freezer Repair)
by jselko 10/14/2023 1:30:11 PM(UTC)
Icemaker for Kenmore 106.51764510 (Forum Announcements)
by jzannini 9/26/2023 12:37:24 PM(UTC)
Why do the prices of IceMaker Cycling Thermostats VARY so much? (Refrigerator & Freezer Repair)
by Mark531 9/6/2023 2:17:44 PM(UTC)
GE refrigerator icemaker freezing up (Refrigerator & Freezer Repair)
by Guest 7/1/2023 6:40:00 AM(UTC)
MFI2269VEM2 icemaker quit (Refrigerator & Freezer Repair)
by Smoreschnapps 5/22/2023 7:06:31 AM(UTC)
GE Undercabint Icemaker (Refrigerator & Freezer Repair)
by rjcunning 4/9/2023 7:35:53 AM(UTC)
no noise when push buttons on icemaker to dispense ice (Refrigerator & Freezer Repair)
by Messenger12 2/27/2023 3:06:18 AM(UTC)
New icemaker failed (Refrigerator & Freezer Repair)
by 7Pat 12/18/2022 11:40:20 AM(UTC)
Buy (200 Pcs) New Insignia - 44 Lb. Portable Nugget Icemaker $39,800 (General Talk)
by eikohajime30 11/9/2022 10:16:55 PM(UTC)
Icemaker Voltage at freezer wire harness (Refrigerator & Freezer Repair)
by mcouvillon 11/1/2022 8:37:12 AM(UTC)
Whirlpool Icemaker NO-OP (model WSF26C3EXF01) (Refrigerator & Freezer Repair)
by Lynster 10/10/2022 2:52:08 PM(UTC)
sub zero icemaker uc15 (Refrigerator & Freezer Repair)
by Guest 9/25/2022 7:21:16 AM(UTC)
