need help figuring out how to replace lid switch.
If you insert a screw driver or stiff putty knife in the gap between the top and front near the edges you will release clips that hold the top to the cabinet. This will allow the top to flip up and you can get access to the parts.
Originally Posted by: sidfink43  If you insert a screw driver or stiff putty knife in the gap between the top and front near the edges you will release clips that hold the top to the cabinet. This will allow the top to flip up and you can get access to the parts. Iam washing right now I will try later and get back. thanks !
