Deano1
#1 Posted : Monday, November 10, 2008 8:58:44 AM(UTC)
Deano1
I have a problem with the oven control. The lock light for the door indicating that it is the self clean mode flashes off and on also the oven door locks randomly. All other oven controls won't work, the range top will function.
The oven hasn't been in the self clean mode for about two weeks. We used the oven since and it worked fine. The oven being to hot is not an issue as it is at ambient temp. When the oven temp sensor is disconnected the oven door locks and won't unlock randomly as when it is connected. Did an ohm check on the oven temp. sensor and it shows continuity.:confused:
Any ideas
Deano
abadfish66
#2 Posted: : Monday, November 10, 2008 9:04:51 AM(UTC)
abadfish66
Most likely problem is the door lock motor, part# WB15T10125
Deano1
#3 Posted : Monday, November 10, 2008 9:28:51 AM(UTC)
Deano1
Door lock motor is located where? Do you have how to replace steps?
Deano:)
abadfish66
#4 Posted : Monday, November 10, 2008 9:44:18 AM(UTC)
abadfish66
It's located under the cooktop. open oven door, and look under the front lip of the cooktop, there are 2 screws. Take them out and lift up on the cooktop and you'll see it.
Deano1
#5 Posted : Monday, November 10, 2008 11:37:21 AM(UTC)
Deano1
I found the motor it appears to we working but never stops, continues to go around and around.
Deano1
#6 Posted : Monday, November 10, 2008 11:54:41 AM(UTC)
Deano1
Located the door lock motor it appears to be working but never stops continues to rotate.
abadfish66
#7 Posted : Monday, November 10, 2008 12:02:48 PM(UTC)
abadfish66
One of those switches on the assembly is most likely bad. The motor turns when you program to self clean and activates the switch to tell the board the door is locked. When clean is done the motor turns and hits the other switch to tell the board the door is unlocked.
