this may be the model number wpre6100g0wt top load washer, Please tell me how to replace the bealt. THANKS
I cannot link you to a manual because GE does not allow access to its tech material, but here are the instructions. The diagrams will not copy, but I think they may be provided with the belt install tool which I recommend you using.
"Since the belt provides constant tension, there is no need for adjustments (an adjustment method is not provided).
A worn or damaged belt can result in excessive brake time and will initiate a motor inverter slipping belt error code. This code will prevent the motor/inverter from operating.
To replace the drive belt it may be helpful to use the belt install tool (part number WX05X10102.
To replace the drive belt using the tool kit:
Note: If not using the belt install tool, follow steps 1 through 3, and 6 through 7. Remove wire tie after step 7.
Disconnect power.
Remove the front panel. (See Front Panel.) Center belt on drive pulley and secure tightly with wire tie as shown on following page. Align wire tie as shown.
Stretch the belt install tool to fit over the end of the motor shaft. (See Figure A.)
Slide belt install tool upward until it snaps into the first groove of the motor shaft. (See Figure B.)
Center belt on motor shaft grooves and slowly turn drive pulley clockwise.
Continue rotating drive pulley until belt is fully engaged. Remove wire tie and belt install tool.
Note:
A new belt will be slightly smaller than the drive pulley.
A belt that has been installed on the drive pulley will stretch to the diameter of the pulley over time. This is normal and does not indicate a bad belt."
