Dryer will tumble but clothes do not dry. Appears to be no air being pulled thru. I took the back panel off as well as the vent hose. Looked up inside and I can barely see the blower fan. When I power on, the fan doesnt turn. For about a week previously, it would dry the clothes but make a grinding sound.
THIS FORUM IS DEAD!!!!!!! |
yes there are 2 belts ,both working of of motor . are you getting heat? you would have to remove front panel to begin with + see what comes of from there to get drum out, drum belt would have to come off also first, blower housing is under drum
I found the pulley had come completely off the shaft for the blower. The threads were pretty much worn off. I ordereda new one.
