ruju
#1 Posted : Monday, April 25, 2011 9:08:22 PM(UTC)
ruju
not sure how old Lady Kenmore gas range model 911.7388710 is (serial number 7K66353). unplugged the range last night just before a doosy of a thunderstorm. plugged range back into the wall outlet today & had buzzing on & off, & got F3 & F6 fault codes after i turned on oven &/or broiler. oven & broiler gas each came on briefly then stopped. they have not come back on. stovetop burners work fine.
i turned off all power in the house on the circuit breaker panel for a few minutes, & after turning back on, the buzzing stopped for several hours then resumed & displayed F6 fault code until I unplugged it to get some sleep.
read online that it was manufactured by Roper or GE. ************************.com has nothing for F6 under GE ranges; same site shows F6 for Roper ranges could be problem in time keeping circuit & to reset time &/or cooking operation, & check for proper ground. i reset the timer, clock, clean door, cook time, etc. & short time later after resetting each i got F6 code. Not sure how to check for proper ground; it's plugged into a 3 slot grounded receptacle.
************************.com shows F3 on GE or Roper as oven temperature sensor problem. Assume there is a control panel thermal fuse, & how do I get to it? I can pull out the oven temp sensor & test it w/ meter. would it help if the oven temp sensor were cleaned or is it too sensitive to clean?
does this sound like a problem with the control panel (for time, clock, cook, clean, bake, etc) or with the oven temp sensor after unplugging power supply before storm & plugging back in w/ buzzing (buzzing stopped after shut down power on circuit breaker & turned back on) & F3/F6 fault codes (mostly F6 codes now)?
doesn't it seem unlikely that it is problem with oven temperature sensor (F3) & panel that controls the functions (F6) (like clock, timer, etc)? i have seen both fault codes on display since this problem started yesterday.
Is there a better way to reset the control panel than what I have done above? thanks
ruju
#2 Posted : Thursday, May 5, 2011 8:04:07 PM(UTC)
ruju
can moderator or others help me with my 4/25/11 post?
also: tonight i plugged range back in & no buzzing, no error codes, & oven bakes & broils. do you think range control panel reset by having it unplugged for over 24 hours? how likely is it buzzing & F3/F6 error codes likely to return? thanks!
boasmar
#3 Posted : Sunday, June 19, 2011 5:42:47 PM(UTC)
boasmar
Had this problem come up with no knowledge on how to fix it. Tried everything, even reseting the breaker to the oven. Nothing worked to reset the display.
I turned off the breaker and went to play golf for about 5 hours, returned to the house, tripped the breaker back on and the oven had mysteriously reset
itself and is now just fine. I guess the computer board had to have enough time to completely drain itself of power and thus was able to reset itself.
If this is a common fix then all is well, just let the oven sit for serveral hours, kill power to the unit, and allow the unit to power down and sit for
a few hours. Go for it.....
