ccpccart
#1 Posted : Monday, May 2, 2011 12:55:32 PM(UTC)
ccpccart
i have the defrost drain freeze up.is there something i can do to correct this?my ad is ccpccart@charter.net
#2 Posted : Monday, May 2, 2011 2:08:33 PM(UTC)
Remove the rear panel in the freezer and defrost the drain using a hair dryer. Make sure the other end of the drain hose is clean. Run some very hot water through the drain using a turkey baster.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ER2CHMXPL00 REFRIGERATOR | AppliancePartsPros.com
ccpccart
#3 Posted : Wednesday, May 4, 2011 9:17:34 AM(UTC)
ccpccart
hi gene.ihave done this 2 times .one post suggested using a copper wire.i may try this next time it is apart.thank you for the help.i'm not to good with the computer but i try.
#4 Posted : Wednesday, May 4, 2011 3:28:50 PM(UTC)
You can install the defrost heat probe kit to prevent such problem. It comes with the installation instructions.
- The defrost heat probe kit Part number: AP3119957
rbstring
#5 Posted : Friday, May 27, 2016 5:27:48 PM(UTC)
rbstring
I have the Defrost Heat Probe Kit #AP3119957 which I ordered to fix the freezer in a Whirlpool model #ER9FHKXTQ00 fridge which chronically freezes up. The kit includes a metal tube but if I try to insert the tube into the defrost drain tube it only goes half way due to the bend in the defrost tube. The defrost tube feels as if it is made of plastic. There was no heat probe in the fridge to start with. How hot does the heat probe get? Will using the heat probe without the metal tube be safe?
Guest (4)
