how to replace the belt on the large wheel and the pulley . Do I need to remove the motor,and if so how. I can not read the model number. the belt has 6 replies 5 croves.Is their a pin to hold the motor still ? what is this long plastic tub on the side of the tub . GE Profile washer Model#wpre6100g0wt:)
It's hard to say it without the complete model number. Also you can not find a replacement belt without the model number. Hopefully the Model Number Locator will help. Gene.
