scotttheis
#1 Posted : Wednesday, May 4, 2011 11:44:12 AM(UTC)
scotttheis
I have an Admiral oven that barely heats up. I recently replaced the element that I got from a local store after our old one got some grease on it and it burned a hole in it. I took the new one back after having used it for a few weeks (it had worked great for a short time) and they tested it and said that the element was good. I now suspect the control unit, but am not sure if that is the right part to get. It costs enough that I don't want to make a mistake and get stuck with a $150ish part that I don't need. I disassembled the back of the oven and got enough numbers to find the following part number on this website: AP4396951
Could it be something else? If so, what? And how would I test the other possible components?
Thanks,
Scott
scotttheis
#2 Posted : Wednesday, May 11, 2011 11:04:41 AM(UTC)
scotttheis
Bump, I really need help with this.
Admiral oven not heating properly (Oven Repair (including Ranges and Cooktops))
by cougar1963 10/29/2010 7:34:18 AM(UTC)
