Yet another F1 error code question, Will the control panel alone be able to fix my f1 error code on my GE JKP54GOV1bb . I did hit clear a few times and it finally stopped beeping, but I have not turned it back on yet to see if it starts again.
Or is there a seperate clock part that I may need to purchase as well.
Thanks in advance
Age: Less than 1 year Why are you buying anything??? Call for warranty service...
typo in original post, the unit is 10-12 years old
ohm out your oven sensor ( should be @ 1070 at room temp ) and check to see if the touch pad is part of or separate from the clock ..
