My kenmore front load washer won't spin I have replaced the speed control board the motor and the door switch. I removed the belt and ran the washer. The motor will only start if you give it a little "help" then it spins. the drum seems to spin fine by hand with the belt removed so I reinstalled the belt and it will try to spin if you help it but it just rocks back and forth and never gets spinning.
Is all the water drained out? If not check for an obstruction in the pump. If the water isn't drained out it won't go into spin.
Nat
the water drains out fine.
The problem itself may be your motor.
Nat
I replaced the motor already, but now when I follow the diagnostic tech sheet I'm getting the same readings with the new motor. The tech sheet says with these results to replace the motor. do you think the new motor could be bad? or is that unlikely?
Not likely but it is possible. If you have already changed all of those I would check the pump for an obstruction. Nat
there is no obstruction in the pump , hose or coin trap
