i have a magic chef oven "electric" fi appears on the screen pad,but then when i un plug pull out the wiring connectors too the pad key and then plug back in it comes up f3 then goes too f1 any ideas? if its a sensor youre diagrams show now sensors just the key pad unit.
The first failure suspect is the control board aka a clock. - The part number for the clock is AP375343 Here are the break down diagrams for the Magic Chef range Model CER3760AAWGene.
