doug221
#1 Posted : Monday, November 3, 2008 4:39:36 AM(UTC)
doug221
water fills ok but will not get water up to the top rack the bottom rack cleans fine which part is it usually
doug221
#2 Posted : Monday, November 3, 2008 4:41:13 AM(UTC)
doug221
the washer fills ok however the top rack rack does not get water only the bottom rack cleans which part is it usually thanks doug
#3 Posted : Monday, November 3, 2008 4:56:06 PM(UTC)
Remove the inlet protector (#8 on the break down diagram) and check the chopper (#6 on the break down diagram).
kenmore dishwasher 66513043K116 still not draining, after changing drain motor? (Dishwasher Repair)
by thivakaran 12/5/2022 11:47:06 AM(UTC)
Repeating Error 24 on Kenmore Dishwasher (Dishwasher Repair)
by abidh2 12/24/2021 4:45:12 PM(UTC)
Kenmore Dishwasher 665.13733K600 Major Leak Problem (Dishwasher Repair)
by Ken More73 11/10/2021 12:22:29 PM(UTC)
Kenmore Dishwasher - no control lights but washer works (Dishwasher Repair)
by toibn46 10/22/2021 10:08:47 AM(UTC)
Kenmore Dishwasher Keeps Running (Dishwasher Repair)
by VicRattlehead 9/21/2021 1:25:13 PM(UTC)
my Kenmore Dishwasher wont start (Dishwasher Repair)
by Guest 6/14/2021 8:14:07 AM(UTC)
Kenmore dishwasher turning on by itself (Dishwasher Repair)
by Guest 5/24/2021 11:06:12 AM(UTC)
Kenmore Dishwasher drain output has stong sulphur smell (Dishwasher Repair)
by Larbo 1/13/2021 3:35:42 PM(UTC)
Kenmore Dishwasher Heater (Dishwasher Repair)
by mikedbom 11/11/2020 4:21:33 PM(UTC)
Kenmore Dishwasher Smartwash (Dishwasher Repair)
by katzman299 1/4/2020 11:02:06 AM(UTC)
Kenmore dishwasher model 665.15113K211 started high pitch sound between cycles (Dishwasher Repair)
by redeyedog 5/10/2019 8:21:48 AM(UTC)
Kenmore Dishwasher control pannel not working (Dishwasher Repair)
by Douglas Scherer 3/14/2019 6:32:33 PM(UTC)
Kenmore Dishwasher fills then drains (Dishwasher Repair)
by qkantaris 1/5/2019 8:39:01 PM(UTC)
How do you install Part W11048936 for a Kenmore Dishwasher (Dishwasher Repair)
by S Hall 3/23/2018 4:46:54 PM(UTC)
Can't loosen impeller part for kenmore dishwasher (Dishwasher Repair)
by rbhall52 9/5/2017 12:04:52 PM(UTC)
