Ejg05vet
#1 Posted : 14 years ago
Ejg05vet
Had repairman today replaced mother board. Now freezer is 24 and fridge 44
#2 Posted : 14 years ago
Impossible for the fridg section to be colder than the freezer.
If reversed, you either have a sealed system problem, or bad thermistors, or a frozen evaporator.
Ejg05vet
#3 Posted : 14 years ago
Ejg05vet
sorry I must have had a typo.
freezer was 24 fridge 42;
this morning it is freezer 23 fridge 40
talked to tech, said it takes 24 hrs to hit desired temps
seems to be taking a long time. freezer came down 1 degree from 10 pm last night to 10 am this am
#4 Posted : 14 years ago
Pull the cover off the back of the freezer and describe the frost pattern, partial frost, heavy frost all over, etc.
Ejg05vet
#5 Posted : 14 years ago
Ejg05vet
there is frost about 1/4 inch thick on most of back wall of freezer.
even though the temp on the front outside panel says 23 and 41, we put a themometer inside freezer and it reads 34. all items are thawed now.
#6 Posted : 14 years ago
If the compressor and all fans keep on running, you have a sealed system problem that was overlooked by the repair guy. I would never use him again, get someone else.
