paulmstew
#1 Posted : Saturday, April 16, 2011 5:06:26 PM(UTC)
paulmstew
GREETINGS,
I have a whirlpool side/side, mod ED5GHEXNQ00. No ice, pan empty. freezer is at zero degrees. I used a jumper wire to diagnos: V and L.... no water, no ice blocking tube. I thought I'd make it run an cylcle just to be sure jumper was working , so jumped T and H, Still nothing, no cycle no sound.
So I'm not sure it needs a water valve. Is there a fuse for the icemaker?
Thoughts?
paulmstew
#2 Posted : Saturday, April 16, 2011 5:09:56 PM(UTC)
paulmstew
I havent changed the filter in forever.... might that do it?
cspar
#3 Posted : Saturday, April 16, 2011 10:33:36 PM(UTC)
cspar
My Whirlpool icemaker stopped as well. No water, icemaker not moving, not able to jump any of the letter combinations on the icemaker and get a response.
Check the sensor light on the right side of your door. I was told this gives power to the icemaker. Mine blinks twice then stops, repeats. When I push the flap on the left side so that the 2 sensors make contact, it still blinks. I was told this means the sensor is bad. It should stay on solid at this time. I ordered it and will have it in by Mon-Tues.
paulmstew
#4 Posted : Sunday, April 17, 2011 7:17:25 AM(UTC)
paulmstew
thanks cspar,
I dont have a light, sadly!
