Alraisca
#1 Posted : Friday, October 31, 2008 12:45:17 PM(UTC)
Alraisca
Hello all
My Jenn-air oven (W30400BC) broiler element operates sporadically. The electronic control panel seems to work (fan comes on, temperature display on) however the top element comes on about 1 or 2 times for every 10 tries. I suspect there is a relay interfacing between the control system and the power supply to the element that is sticking. Before I launch myself into the guts of the oven, does anyone have access to a wiring diagram? Failing that, some help identifying the correct relay (location, color, shape, or?) would be appreciated.
Thanks in advance
Alraisca
kayakcrzy
#2 Posted : Friday, October 31, 2008 11:32:18 PM(UTC)
kayakcrzy
Your oven control needs to be replaced, unless you are an electronic technician and can diagnose the electronic conponents on the board. UserPostedImage
kayakcrzy
#3 Posted : Friday, October 31, 2008 11:33:14 PM(UTC)
kayakcrzy
I don't think this will help but here you go. Tom ApplianceEducator.com
Alraisca
#4 Posted : Saturday, November 1, 2008 9:03:24 AM(UTC)
Alraisca
I appreciate the info Kayakcrzy. I was hoping the relays were free-standing units (easy to replace!). A little too simplistic as usual. At least I know what I'm dealing with now.
Thanks again
Alraisca
kayakcrzy
#5 Posted : Sunday, November 2, 2008 3:31:10 AM(UTC)
kayakcrzy
Good Luck. Tom ApplianceEducator.com
