AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Front Loader Frigidaire washes does not drain or spin
Hello
My Front loader will agitate but does not drain, the timer does advance.
I just replaced one of the springs and ran a load everything worked. Next we tried a regular load now the machine will only agitate.
Any clues?
Best Regards Phil
Clogged up pump impeller.
Unplug power Bail out tub open bottom panel have a small bowl to catch water from the drain hoses as you detach clean drain hose and impeller from all forgien objects put everything back together.
mine had $2.25 worth of dimes, nickels and pennies Also a piece of plastic was jammed in the impeller of the pump
Phil
Washer Repair
