pboulo
#1 Posted : Thursday, October 30, 2008 4:58:11 PM(UTC)
pboulo
Hello
My Front loader will agitate but does not drain, the timer does advance.
I just replaced one of the springs and ran a load everything worked. Next we tried a regular load now the machine will only agitate.
Any clues?
Best Regards
Phil
pboulo
#2 Posted : Friday, October 31, 2008 10:09:12 AM(UTC)
pboulo
Clogged up pump impeller.
Unplug power
Bail out tub
open bottom panel
have a small bowl to catch water from the drain hoses as you detach
clean drain hose and impeller from all forgien objects
put everything back together.
mine had $2.25 worth of dimes, nickels and pennies
Also a piece of plastic was jammed in the impeller of the pump
Phil
