pritch99
#1 Posted : Friday, October 31, 2008 10:03:04 AM(UTC)
pritch99
washer dischager backs up in drain so i sleeved tubing over it and discharge hose, no more back up but now it seems like theres a vacum on the discharge hose because it drains as it fills after 1st agatation cycle. any ideas folks .....thaks
libertyappl
#2 Posted : Friday, October 31, 2008 12:23:25 PM(UTC)
libertyappl
The drain line needs air flow to drain properly. you need to remove the sleeve part you put on and check you household drain for a stoppage if you are getting a back flow.
Nat
