BryanM
#1 Posted : Monday, April 11, 2011 8:51:57 AM(UTC)
BryanM
Opened door after washing and tub seal twisted spring came out and long wire is there something more wrong than the front tub seal or is it the bearing? How much movement should the tub have exactly how do you really know if the bearing is bad?
sidfink43
#2 Posted : Wednesday, April 13, 2011 7:52:26 AM(UTC)
sidfink43
Use this service manual as a guide to put the spring back on. You may need a new one though.
https://secured.whirlpoo...ILE/Duet%20Job%20Aid.pdf
Can say about the tub without being there. Take off the back and check out the support shocks and springs.
rtbme
#3 Posted : Friday, April 15, 2011 4:38:15 AM(UTC)
rtbme
use a piece of wire (coat hanger) put a hook on the end to pull the wire/spring back in place. Thats after you've determined all thats wrong is the retainer wire/spring simply popped out of place.
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool duet washer not draining (Washer Repair)
by Guest 2/16/2022 8:40:23 AM(UTC)
Whirlpool Duet Washer - Wire broken off connector on harness (Washer Repair)
by Cephalon 1/21/2021 9:33:49 PM(UTC)
Whirlpool Duet Washer Codes (Washer Repair)
by mbocon 3/10/2020 5:04:51 PM(UTC)
Whirlpool duet washer (Dishwasher Repair)
by Julia Johnson 11/1/2017 9:53:41 AM(UTC)
What happened to my Whirlpool Duet washer?? (Washer Repair)
by colbran 10/2/2017 12:01:48 PM(UTC)
Whirlpool Duet Washer (Washer Repair)
by Bmbrouillette 7/2/2017 11:05:32 AM(UTC)
Whirlpool duet washer- won't start after replacing CCU and door latch (Washer Repair)
by Ivanick 5/22/2017 6:07:41 PM(UTC)
Whirlpool Duet washer FH code (Washer Repair)
by farmgirl 1/17/2017 7:14:25 PM(UTC)
whirlpool duet washer F06 E02 error (Washer Repair)
by tnafranklin 10/18/2016 12:47:55 PM(UTC)
whirlpool duet washer (Washer Repair)
by Oathose 4/4/2016 7:23:01 PM(UTC)
Whirlpool Duet Washer bellow tore in two. (Washer Repair)
by pitwoman 1/28/2016 5:42:42 PM(UTC)
by CrosbyFamilyFarm 12/31/2015 1:28:32 PM(UTC)
Whirlpool Duet Washer not working (Washer Repair)
by Shanej69 11/23/2015 1:59:18 PM(UTC)
Whirlpool Duet washer start button is broken (Washer Repair)
by bjgamble 9/7/2015 7:04:46 AM(UTC)
