2 Pages<12
v2k04
#11 Posted : Thursday, October 30, 2008 10:11:11 AM(UTC)
v2k04
OHM out the timer contacts if thats possible without a wiring diagram if that machine is all butchered up the guy probably fried the timer in it the two thick red wires should be the ones carring voltage to element
magician59
#12 Posted : Friday, October 31, 2008 8:46:42 AM(UTC)
magician59
Originally Posted by: libertyappl Go to Quoted Post
Correct, If you are only getting 110V make sure your have 220V at the wall plug.
Nat
Whoa! Isn't the 220 in electric dryers split--110 for the motor, and 110 for the heat?
libertyappl
#13 Posted : Friday, October 31, 2008 9:29:46 AM(UTC)
libertyappl
NO the heat element needs 220 to work.
Nat
2 Pages<12
