kyongmi1
#1 Posted : Thursday, April 14, 2011 2:41:35 PM(UTC)
kyongmi1
i have a top load washer, and it spins an d finishes the cycle but the problem that I am having is when the cycle is done, the clothes are still wet with excess water.
#2 Posted : Thursday, April 14, 2011 3:48:47 PM(UTC)
Remove the washer front panel and check all drain hoses. Post the results.
Here are the breakdown diagrams and Replacement parts for MAYTAG MAV3905AWW WASHER-TOP LOADING | AppliancePartsPros.com
P.S. Does it make any excessive noise during the cycle?
jimtone
#3 Posted : Sunday, November 11, 2012 9:06:41 AM(UTC)
jimtone
My Maytag model MAV3905AWW fills and agitates, but won't go into spin/drain cycle? Is this a common problem with these models and is there something I should look for to determine the trouble?
#4 Posted : Sunday, November 11, 2012 1:59:18 PM(UTC)
Tilt the washer back and remove the belt. Check belt for any worn out signs. Check how freely the pump pulley rotates in both directions.
Remove the front panel and make sure the drain hoses are not clogged.
Post the results.
Here are the breakdown diagrams and Parts for Maytag MAV3905AWW Washer - AppliancePartsPros.com
jimtone
#5 Posted : Wednesday, March 27, 2013 5:27:23 PM(UTC)
jimtone
Post the results.
I'm going to hook it back up and try the things you suggested. It is a back up washer I have at a whse. that's been broken for several years but I don't want to discard it because it is very unused before it broke.
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Amana top load washer model NTW4600 (Washer Repair)
by Guest 5/2/2024 8:47:15 AM(UTC)
Frigidaire max load top load washer (Washer Repair)
by Guest 4/29/2024 9:02:43 AM(UTC)
Speed Queen top load washer model AWN412SP111TW01 (Washer Repair)
by Guest 4/28/2024 6:36:53 PM(UTC)
Samsung top load washer won’t start (Washer Repair)
by aw2055989 4/19/2024 4:42:33 AM(UTC)
Speed Queen top load washer model AWNE82SP113TW01 (Washer Repair)
by Guest 2/2/2024 10:12:50 AM(UTC)
GE Washer Topload model I have a GE top load washer GTW750CPL0DG. It fills and it is running but whe (Washer Repair)
by MimiReel 1/28/2024 12:03:27 PM(UTC)
Speed Queen top load washer modelAWN542SP111TW01 (Washer Repair)
by Guest 1/27/2024 10:43:32 AM(UTC)
Speed Queen top load washer model AWN542SP111TW01 (Washer Repair)
by Guest 1/13/2024 1:28:32 AM(UTC)
Speed Queen top load washer (Washer Repair)
by Guest 12/23/2023 3:02:14 AM(UTC)
Speed Queen top load washer typical model AWNE82SP113 (Dryer Repair)
by Guest 12/1/2023 8:26:13 AM(UTC)
Maytag Legacy top load washer not spinning (Washer Repair)
by Guest 10/28/2023 8:56:04 AM(UTC)
Speed Queen top load washer model AWS17NW (Washer Repair)
by Guest 10/16/2023 11:23:35 AM(UTC)
