Samsung top load washer has no response from anything on the control panel. No lights, nothing. Tub nut loosened up on me so I tightened it up and then put it back together and now all I get are clicks from the relays when and nothing when pushing the power button. No lights on display. Everything looks to be hooked up properly. Was thinking lid switches, but everything worked fine before I took it apart to tighten that nut.
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
AW2055989, the control area in the console would need to be checked for any wires that may have come loose. If there is not a wire issue found, the most likely failure would be the main control.
So I replaced the larger of the 2 boards, I believe that’s the user interface board, correct? And the smaller one is the main control board? that smaller board has a blinking red light on it. The board that I replaced when I plug in the washer it just clicks every 15 to 20 seconds without me pushing any buttons.
There are three controls used with this particular model. The user interface would be the forward-facing control while the main control and inverter sit behind it. The main control will have black relay boxes on it and the inverter will have an aluminum cooling fin. For the most accurate part information, there should be two letters at the end of the model and an REV number or two digits next to the model that would be needed.
