oshunne
#1 Posted : Friday, October 31, 2008 4:51:03 AM(UTC)
oshunne
DRYER KEEPS TRIPPING CICUIT BREAKER, WHEN i RESET THA BREAKER AND PLUG DRYER BACK IN SPARKS FROM DRYER PLEASE HELP:confused:
icehouse
#2 Posted : Friday, October 31, 2008 6:11:08 AM(UTC)
icehouse
First a name of machine helps. Also is it gas or electric, anyhow you h a short somewhere. Help us help yo by giving all proper information. :)
libertyappl
#3 Posted : Friday, October 31, 2008 7:51:23 AM(UTC)
libertyappl
After looking at the model number I'm guessing this is the correct number WER211ES0 which would make it a White-Westinghouse dryer.
Nat
magician59
#4 Posted : Friday, October 31, 2008 8:07:18 AM(UTC)
magician59
First thing I would do is check for continuity between each of the power cord terminals and ground. If there is, you have a dead short and the connections at the wiring block need to be checked. Then I would check for the same thing between the two hot terminals. (If it's a four conductor cord, check for continuity between each hot terminal and Neutral). That's a logical place to start checking, and the easiest to check.
Guest (4)
