I am getting the error messages SE (or 5E) and then "Press 1-4". I spoke to a gal at Appliance Parts Pros and she told me I just needed to order the Control Panel (SAM DE94-01647A) for about $39 which I did. Said I didn't need everything else. I ordered it and just installed it and I'm getting the same messages. Clearly that wasn't what I needed. Any suggestions?
Thanks!
Becky, In case of the "SE" error code the manufacturer suggested to replace the control panel first. If it would not fix the problem then the smart board should be replaced too. - The smart board Part number: AP4336911
