mckrsix
#1 Posted : 17 years ago
mckrsix
All burners (GE Select) when turned on (together or not) goes on and off unless its in the very high setting?
#2 Posted : 17 years ago
Seems normal to me, do the burners heat up well at a medium control setting?
mckrsix
#3 Posted : 17 years ago
mckrsix
Well my wife tried to cook noodles on high and it comes almost a boil and then you see it turn off. Then a little bit later it turns back on. They all do this the oven is fine though. Its plugged in to a 15Amp circuit. Its just odd.So they share a common junction of some sort. (thermostat,power surge/draw thru circuit or ?) As far as the Medium setting I tryed it turns on for about 6 to 8 seconds and kicks off. No pan on it.
#4 Posted : 17 years ago
You have a bad burner control, just click on model # to order.
mckrsix
#5 Posted : 17 years ago
mckrsix
All 4 have a bad control? They all do it. They all have there own controller right?
#6 Posted : 17 years ago
Turn on all the burner controls to high. Now, do they all go off at the same time??
mckrsix
#7 Posted : 17 years ago
mckrsix
So I turned them on high they all seemed to stay on > So then I put a pan of water on them. Moved the pan to each burner (on high still) Thats when the burner starts to turn on and off when the pan is on them? It takes less than a min for the burners to do this. The water by the way did not boil. I must be missing something or what!? heck it could be normal but the water still didn't boil. By the way when they are not on high and all on a setting of eight they seemed to turn off some what close to each other but no not at the same time.
#8 Posted : 17 years ago
Hi mckrsix
In order to provide you with accurate advise I need the complete model number of your range.
#9 Posted : 17 years ago
Need make and model # for this.
Each burner has a over temperature thermostat. Usually takes a few minutes to click back on. If this is true, you have problems with each burner.
Check your line voltage, might be higher than 240 volts, if so that would be your problem
mckrsix
#10 Posted : 17 years ago
mckrsix
Hi, Pain in the but here again. The model number is JBP61WB1WW GE Select. 240v I haven't thought of that I will check I would be surprised though.
Thank you!!
