Mott4
#1 Posted : Wednesday, April 13, 2011 9:05:31 AM(UTC)
Mott4
I was told that I have an [FONT='Calibri','sans-serif']adaptive defrost control board on my refrigerator. Can this be tested or does it just have to be replaced?[/FONT]
[FONT='Calibri','sans-serif'][/FONT]
[FONT='Calibri','sans-serif']My refrigerator side of my side by side is gets warm. I then will defrost the coil and it works for 7-10 days but then is warm again. I was told to check my defrost timer but i am told ine does not have one of those it has an [FONT='Calibri','sans-serif']adaptive defrost control board instead.[/FONT][/FONT]
#2 Posted : Wednesday, April 13, 2011 11:06:31 AM(UTC)
Replacement parts for ADMIRAL LSD2615HEB REF - SXS/I&W | AppliancePartsPros.com
Yes you have an adaptive defrost board (Item 12 in Section 3)
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle, see the tech sheet.
Compressor and fans will shut off
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the board needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 7 in Section 6) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 3 in Section 6) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost board is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
File Attachment(s):
LSD2615.pdf (171kb) downloaded 228 time(s).
