The top section of the spray tube cam out I am trying to wedge it back in but no go, I was trying to find info on how to take the assembly apart so I can slide it in from the bottom
any ideas
Originally Posted by: bipshoft  The top section of the spray tube cam out I am trying to wedge it back in but no go, I was trying to find info on how to take the assembly apart so I can slide it in from the bottom
any ideas Is this the part you're working on ? Part number: AP2039808
If so, you unscrew the bottom portion from the spray arm assembly and go from there. Are you sure there's nothing broken ? Good Luck, :cool: :cool: :cool:
Originally Posted by: Joe / APP Team  Is this the part you're working on ? Part number: AP2039808
If so, you unscrew the bottom portion from the spray arm assembly and go from there. Are you sure there's nothing broken ? Good Luck, :cool: :cool: :cool: It does not look like that at the base looks like a flush fit, does have a angled plate that has a bolt holding it on to the bottom portion of the tube, also appears that there is a water feed for the bottom portion as well wish I had a picture
any ideas Does your spray arm look like part no. 501 in this parts diagram ? https://genet.geappliances.com/I...0060000/00060078.p03.pdfIf so, its not repairable, it's a one piece assembly, and you'll have to order and replace the complete assembly. :cool: :cool: :cool:
That part 501 is the part I need. Is it easy to replace? What is the exact code for it to find the cost?? Thanks
Originally Posted by: lmhc  That part 501 is the part I need. Is it easy to replace? What is the exact code for it to find the cost?? Thanks Imhc, Here's the information you need, (click on part number for additional information) Part number: AP4297555
Basic instructions " The lower spray wash arm can be removed by gently lifting and rotating it counter clockwise."This should get you going. Good Luck, :) :) :)
