bipshoft
#1 Posted : Wednesday, October 27, 2010 10:06:20 AM(UTC)
bipshoft
The top section of the spray tube cam out
I am trying to wedge it back in but no go, I was trying to find info on how to take the assembly apart so I can slide it in from the bottom
any ideas
Joe / APP Team
#2 Posted : Wednesday, October 27, 2010 10:46:11 AM(UTC)
Joe / APP Team
any ideas
Is this the part you're working on ?
Part number: AP2039808
If so, you unscrew the bottom portion from the spray arm assembly and go from there.
Are you sure there's nothing broken ?
Good Luck,
:cool: :cool: :cool:
bipshoft
#3 Posted : Wednesday, October 27, 2010 11:00:17 AM(UTC)
bipshoft
Good Luck,
It does not look like that at the base
looks like a flush fit, does have a angled plate that has a bolt holding it on to the bottom portion of the tube, also appears that there is a water feed for the bottom portion as well
wish I had a picture
Joe / APP Team
#4 Posted : Wednesday, October 27, 2010 2:37:01 PM(UTC)
Joe / APP Team
any ideas
Does your spray arm look like part no. 501 in this parts diagram ?
https://genet.geappliances.com/I...0060000/00060078.p03.pdf
If so, its not repairable, it's a one piece assembly, and you'll have to order and replace the complete assembly.
lmhc
#5 Posted : Wednesday, April 13, 2011 9:33:35 AM(UTC)
lmhc
That part 501 is the part I need. Is it easy to replace? What is the exact code for it to find the cost?? Thanks
Joe / APP Team
#6 Posted : Wednesday, April 13, 2011 10:36:21 AM(UTC)
Joe / APP Team
Imhc,
Here's the information you need,
(click on part number for additional information)
Part number: AP4297555
Basic instructions
"The lower spray wash arm can be removed by gently lifting and rotating it counter clockwise."
This should get you going.
Good Luck,
