2 Pages12>
Rhandyman
#1 Posted : Wednesday, March 23, 2011 10:27:00 AM(UTC)
Rhandyman
I started getting F3 error code intermittently on our 8-year old Jenn-Air gas range; also once or twice I got an F1 error. Yesterday I replaced the oven temperature probe, which I thought would correct the F3 fault. Alas, today it is back with a vengence, even showing up occasionally with its buddy F1. Suggestions?
Motormouth
#2 Posted : Tuesday, April 12, 2011 11:07:17 AM(UTC)
Motormouth
I've had this same issue. I'm not sure if I replace the touch pad or the control board?
#3 Posted : Tuesday, April 12, 2011 3:14:45 PM(UTC)
Did you check the wire harness from the oven sensor (temperature probe) to the control board?
Try to eliminate the oven sensor quick disconnect plug and hard wire the sensor using a high temperature porcelain wire nuts.
If it would not help, replace the control board.
- The high temperature porcelain wire nuts Part number: AP3440631
Cornichon
#4 Posted : Monday, July 30, 2012 4:42:32 AM(UTC)
Cornichon
I've been getting an F1-7 error message. Have to turn off breaker to stop the beeping. After a rest, the stove is fine and I can heat the oven, but eventually it starts beeping again and shuts the oven off. Could this be the heat sensor only? Or likely to be other? How do I test the heat sensor? The control panel works great. Many thanks.
Simon / APP Team
#5 Posted : Monday, July 30, 2012 11:45:31 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What is the model and serial number of the unit?
Simon.
Cornichon
#6 Posted : Tuesday, July 31, 2012 7:00:25 AM(UTC)
Cornichon
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Model # JGS8750ADS
Serial # 15147899GJ
Thanks!
#7 Posted : Tuesday, July 31, 2012 10:52:24 AM(UTC)
Originally Posted by: Cornichon Go to Quoted Post
Model # JGS8750ADS
Serial # 15147899GJ
Thanks!
The "F1-7" error code means the control senses the membrane switch disconnected. Such problem has nothing to do with the oven temperature sensor.
Open the control panel. Remove the ribbon cable from the keypad to the control board at the control board. The edge connector can be cleaned with a pencil eraser. Check the tracks in the ribbon cable for a hairline cracks using a magnifying glass. Clean the connector on the board with an electronics contact cleaner or isopropyl alcohol and a tooth brush. Do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
Post the results.
Here are the breakdown diagrams and Replacement parts for Jenn-Air JGS8750ADS RANGE- S/C S/I GAS | AppliancePartsPros.com
barbaraflowers57
#8 Posted : Friday, February 8, 2013 11:22:38 PM(UTC)
barbaraflowers57
gene,yes sometimes it shows f1 and sometimes it don't. the oven beeps even when it's not in use,I tried again last night to bake and it would only preheat to three hundred, and it baked for about ten minutes and shut off,I reset the heating to three hundred and it finished baking.I have no clue.:eek:
barbaraflowers57
#9 Posted : Friday, February 8, 2013 11:26:32 PM(UTC)
barbaraflowers57
having the same problems
barbaraflowers57
#10 Posted : Friday, February 8, 2013 11:28:17 PM(UTC)
barbaraflowers57
Guest (5)
F1 and F3 error codes (Oven Repair (including Ranges and Cooktops))
by Rhandyman 3/23/2011 10:25:34 AM(UTC)
2 Pages12>
