I am trying to replace the lid switch kit and am not sure how to get to it. I took the control panel cover off but not sure how to lift the top off. There seems to be two plastic"clips" on the back of the washer holding the top on. How do I remove them? I need instructions on how to take the washer apart if anyone can help. Thanks
Grab the top by the sides and slide forward a little and you can raise them top. Nat
