hi have a door that is cracked.. it's cracked on the bottom, the " pretty" part I guess.. right where the screws go in underneath.. anyone have an idea as to what this part number might be.. I am assuming I can just replace the door..
I'm afraid I did not get it clear. Can you explain which part of the door cracked, using the numbers from the break down diagram? If you are looking for the complete door assembly, post the color of the microwave, please. Gene.
Gene thanks for the reply, I have looked at the diagram, The part I need is part 10 the outside frame.. it's a bisque or almond color.. thanks for the info thus far..
The part number for the almond outer door frame is AP3118047 The part number for the bisque outer door frame is AP3118086 The part number for the almond complete door assembly is AP3176865 The part number for the bisque complete door assembly is AP3176866 Gene.
Thanks a bunch.. you are a genius! You will solve my ugly door problem for turkey day!! Kudos to you:D
