jeepingcons
#1 Posted : Friday, October 24, 2008 4:43:14 PM(UTC)
jeepingcons
hi have a door that is cracked.. it's cracked on the bottom, the " pretty" part I guess.. right where the screws go in underneath.. anyone have an idea as to what this part number might be.. I am assuming I can just replace the door..
#2 Posted : Saturday, October 25, 2008 4:14:51 PM(UTC)
I'm afraid I did not get it clear. Can you explain which part of the door cracked, using the numbers from the break down diagram? If you are looking for the complete door assembly, post the color of the microwave, please.
jeepingcons
#3 Posted : Monday, October 27, 2008 7:27:51 PM(UTC)
jeepingcons
Gene thanks for the reply, I have looked at the diagram, The part I need is part 10 the outside frame.. it's a bisque or almond color.. thanks for the info thus far..
#4 Posted : Monday, October 27, 2008 7:55:30 PM(UTC)
The part number for the almond outer door frame is AP3118047
The part number for the bisque outer door frame is AP3118086
The part number for the almond complete door assembly is AP3176865
The part number for the bisque complete door assembly is AP3176866
jeepingcons
#5 Posted : Tuesday, October 28, 2008 7:16:48 PM(UTC)
jeepingcons
Thanks a bunch.. you are a genius! You will solve my ugly door problem for turkey day!! Kudos to you:D
#6 Posted : Tuesday, October 28, 2008 7:23:21 PM(UTC)
Oven glass door cracked - need to replace? (Oven Repair (including Ranges and Cooktops))
by scottly 4/16/2009 6:57:57 AM(UTC)
