You have been a member since:: 4/9/2011(UTC) Posts: 3
I am looking for an suggestion on my whirlpool washer. I think I am having a problem with my timer. The machine will wash and when the end of the wash agitation it will not go farther. When I then turn the timer knob a extra turn, the machine continues to work. Do I need to replace the timer or is do you have a suggestion?
Since everything seems to work mechanically I think you do have a timer problem. Try replacing it and see if that fixes things.
If you need more info, repost but check your model number as I think you have a typo in it and we cannot see what model you have.
I put a new $100 timer in my Whirlpool LXR9445JQO and it stops at the same 6min in any cycle. Rarely it can be restarted in the Rinse, but I'm still looking for a better fix (and refund on my timer).
Mark
Please start a new thread and include your model number and a good description of your problem and what you have done so far.
If you purchased your parts from this site you can return it for a refund, see the returns policy for details and conditions.
