2 Pages<12
#11 Posted : 17 years ago
You should buy th special spanner wrench available at appliance parts pros, and they will have the drive block also.
oldman60
#12 Posted : 17 years ago
oldman60
i now understand the clutch operation.it is designed to slip and when worn it slips too easily.you can temp fix by increasing spring pressure by stretching spring slightly about 1/4 inch.also make sure no oil or grease is inside clutch drum.i am now working on finding suitable clutch pad material replacements as they are simply riveted on and can be changed.
#13 Posted : 17 years ago
The clutch assembly is available Pn 285785. Make sure the brake shoes aren't dragging or you will wear the clutch out again. Also the basket drive block is available Pn. 389140
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 12 months ago
Samsung washer won't spin (Washer Repair)
by Guest 3 years ago
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 3 years ago
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4 years ago
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 5 years ago
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 6 years ago
Washer won't spin out. (Washer Repair)
by DJChad818 7 years ago
Washer won't spin (Washer Repair)
by Fingers123 7 years ago
Washer Won't Spin (Washer Repair)
by je00409 8 years ago
Washer won't spin or agitate (Washer Repair)
by dhughes 8 years ago
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 8 years ago
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 8 years ago
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 8 years ago
maytag washer won't spin fast (Washer Repair)
by benp1 8 years ago
by lmhansgen 9 years ago
2 Pages<12
