Cartographer
#1 Posted : Monday, October 27, 2008 3:33:26 PM(UTC)
Cartographer
Greetings all...
I'm trying to replace the Electronic Controll assembly for my KitchenAid Diswahwasher (KUDS01FLSS6). I have the part and can unconnect the wiring, but can't figure out how to remove the part from the dishwasher panel. It is held into place with ridgid clips that I don't want to break. Any help out there? Thanks!
#2 Posted : Tuesday, October 28, 2008 11:42:40 AM(UTC)
There is only one way how to remove the control board: carefully use a flat bladed screwdriver to depress the holding tabs at the left end of the control board housing while pulling up.
Cartographer
#3 Posted : Tuesday, October 28, 2008 11:47:52 AM(UTC)
Cartographer
Gene...Thanks for that reply. I actually finally figured that out yesterday. The confusing thing for those that have this issue is that the board is shipped in a grey casing that one might think needs to be completely used to replace the board/casing already there. In fact you need to remove the board as you said and simply go board for board. Tahnks Again!!!
Replace Electronic Control Assembly? (Dishwasher Repair)
by rhow 3/9/2012 5:05:59 AM(UTC)
Dishwasher electronic control assembly did not fix problem (Dishwasher Repair)
by dpw-ct 1/17/2012 1:52:12 PM(UTC)
Electronic control assembly replacement (Dishwasher Repair)
by materman 5/24/2010 7:53:41 AM(UTC)
Electronic Control Assembly - Part #8530929 (Dishwasher Repair)
by Gary C 3/14/2009 11:27:41 AM(UTC)
Electronic Control Assembly (Oven Repair (including Ranges and Cooktops))
by coollx 10/28/2008 7:07:07 AM(UTC)
dryer electronic control assembly part different from original (Dryer Repair)
by LloydHofer 10/22/2008 11:36:12 AM(UTC)
